| eD2k web links are not added to eMuleIf eD2k web links are not added to eMule when clicked on in the Internet Explorer,
  the special eD2k link format is not correctly associated. Check the eD2k Links
  button in Preferences -> General. If the button is inactive (greyed
  out) then some entries in Window's registry are messed up. Download this
  tool (by Resterampe) and remove the old association, then press the eD2k
  Link button again.
 These registry entries are responsible for the web link format:HKEY_CLASSES_ROOT\ed2k\shell\open\command
 Type: REG_SZ
 Data: "Path to emule.exe(with quotes!)" %1
 and  HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ed2k\shell\open\command same as above
 OperaOpera 7.2x and above
 Run eMule. In Opera go to File -> Preferences -> Programs and paths
  -> Protocols and press the Add button. In the upcoming dialog
  enter ed2k in the Protocol field and the path to eMule automatically
  appears in the Open with default application. If it does not, the correct
  path to the eMule.exe will have to be provided in the Open with other application
  field.
 Older Opera versions:
 To allow weblinks to work from Opera, a configuration file in Opera's installation
  folder has to be edited. Quit Opera and open either one of the files in an editor,
  e.g. notepad.
 Opera 6.x:
 Add the line TrustedExternalURLProtocols=ed2k under [User Prefs]
   in the file Opera6.ini and safe it.
 Opera 7.x:
 For Opera 7.x add the same line in the file OperaDef6.ini.
 Mozilla, FirefoxYou will need a special plugin to associate different link formats like eD2k
  to the Mozialla or Firefox browser. Get mozex
  (alternate download
  link), open your browsers preferences and enter
 path_to_eMule\emule.exe %r
 in the eD2k edit box of the mozex plugin.
 e.g.: C:\ProgramFiles\eMule\emule.exe %r |
